Home > Maintenance & Mods (L322) > Finding a template.
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Finding a template.
It's a long story that I won't bore you with but I need to remove the VOGUE SE badge from the rear of my RR and then clean up the adhesive and re mount the letters in the correct place on the rear boot lid. My problem is I do not have a template for this job and can find none on line. Does anyone have an old one I could purchase or the knowledge how to find one on line.
Thanx in advance for any help. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #153546 26th Nov 2012 10:16am
before you remove the letters, make your own template and then use that when you reapply.... ... - .- -.
Post #153548 26th Nov 2012 10:20am
Pfazz
The problem is the letters are not exactly in the places they should be so making the template myself is a non starter. Agueroooooooooo. 93-20
Post #153553 26th Nov 2012 10:29am
This may sound daft, but go to a land Rover agents armed with some masking tape, a black pen, a measure and a camera...
Find the right model then tape around the letters on the boot, making sure you tape right & left/up & down to reference points so when you peel it all off in one, you can stick it back onto yours using the same reference points...
Measure from the badge each way and write on the tape the measurements so then you can double check with yours...
Hope that all helps?
Craig Thumbs Up
Post #153554 26th Nov 2012 10:30am
thought that might be the reason .. Craigs idea is one way to go unless someone here will measure up for you and post the results... ... - .- -.
Post #153555 26th Nov 2012 10:35am
Where in Manc are you Pfazz?
are you doing the TDV8 badge as well or just the Vogue Se ones?
Being a 2011 car yours should be covered under warranty unless this is something thats happened outside the LR network? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #153559 26th Nov 2012 10:40am
Pfazz
I'm in stalybridge, and no the TDV8 badge is ok. The problem is I bought the car in Epsom and even though it is an SE it came badged as just a vogue. The dealer in got it from assured me that after mid 2011 they only came badged as VOGUE and like a fool I took this as the truth. It has been in to Guy Salmon for some warranty work but when I raised the subject of the missing badges the said badges were not covered under warranty but if I paid for them then they would fit them free which they did. The problem arises because the badges on a VOGUE are stuck on in a different position than they are with a VOGUE SE and Guy Salmon just stuck the SE on the end of the existing VOGUE and even though it's ok I know every time I see the badge it is not quite right and it's bloody annoying so it wil have to be done even if I finish up buying all new letters and template complete. Agueroooooooooo. 93-20
Post #153561 26th Nov 2012 10:58am
If you buy them new from Dan @ Duckworths, they come with a template ready to stick on...
Craig Thumbs Up
Post #153586 26th Nov 2012 12:14pm
Pfazz
Seems a shame to throw perfectly good badges away just because of a template but I will order some if I can't sort it. Agueroooooooooo. 93-20
Post #153614 26th Nov 2012 1:21pm
