Home > Technical (L322) > Battery warning light on
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
last week I had my battery warning light on my dash popping up from time to time (plus HDC Inactiv).
Yesterday I changed my 2 year old Varta 110Ah for a new one, on my TD6. This morning, warning light is still popping on and off, and still getting the HDC Inactiv.
Battery had >12.5V yesterday. Old one > 12.3V
Any Ideas where this can come from? Is the alternator on it’s way out or a gremlin coming in?
In the secret functions, I had a very stable 13.7V when running showing on my dash.
Thanks for your Help
Post #153521 26th Nov 2012 9:07am
did you follow the battery dis/re connection procedure in our wiki.... ... - .- -.
Post #153523 26th Nov 2012 9:15am
L322RR
Hi Stan,
Yes and I did removed the earth first and then the positive.
Post #153549 26th Nov 2012 10:21am
i gather that you also did the steering fully left and then fully right, if so then check the voltage when running with a multimeter, it should be around 14.5 volts... ... - .- -.
Post #153551 26th Nov 2012 10:24am
Alternator would be my guess if batt light is on. Does the TD6 have a separate belt for it that could be slipping g if its intermittent. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #153560 26th Nov 2012 10:55am
L322RR
Hi,
small update, after a 20 minute ride with the new battery, the ligth stopped coming on.
Did some tests this morning, unfortunetly the bonnet cabled snapped.
I measured (before the cable snapped), with my voltmeter at the terminals 12.2V (I guess some ecu's where already taking some power) and a bit more then 14v at iddle.
My guess is that new battery was not completly new, if the aternator was shot after a week of short drives with lights and heater etc on battery would be flat.
Is this correct?
Thanks for your help.
Post #154713 1st Dec 2012 2:59pm
