Home > Technical (L322) > Pre Heat
mjdronfield
Pre Heat
Having got my pixel issue nearly sorted yesterday, I noticed the message "Pre Heat" appear on the display this morning when I started the car.
I understand this to be the Fuel Burning Heater kicking in to help the water heat up etc, but when I looked in my manual I saw ;
It says to deactivate the system if I don't want it.
Can't see any other reference to this anywhere in the manual though.
Does that mean there is a way to just turn it off the one time, ie if you are doing a short journey, or does that mean to deactivate it permanantly if you don't want the heater, if you see what I mean ?
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #153183 24th Nov 2012 8:06pm
Andy
I think it comes on under a certain temperature? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #153205 24th Nov 2012 8:38pm
mjdronfield
Cheers noddy,
Yeah, I think I follow when it comes on, and what its supposed to do, its just the bit where the manual says "deactivate if not required".
I assume this means "at the dealer", and the FBH will not operate from then on, or is there some sort of button press somewhere that turns it off just for that journey ? Like a one shot override........
Think it just means at the dealer..........or with IID Tool etc..........as oppose to "if you press the heated steering wheel button within 5 seconds of the Pre Heating being displayed, the FBH will stop..........for example.
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #153212 24th Nov 2012 8:50pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I thought this was to heat your spark plugs in very cold weather? So it's to heat the car?
Post #153213 24th Nov 2012 8:52pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think you'll find the "pre heat" is warming up your glow plugs to ensure easy starting.
Wait till the displayed words disappear then start up.
Post #153217 24th Nov 2012 8:57pm
mjdronfield
Well thats a different take on it.
There is nothing about it in the Starting section of the manual.
If I were a betting man, I'd say its for the FBH...........maybe I'm totally wrong.
If its for the glow plugs (mines a Td6) why would you want the option to deactivate it ?
Mmmmm 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #153220 24th Nov 2012 9:02pm
As Paul says "Pre-heat" refers to the fact the glowplugs are heating, nothing to do with FBH. Thumbs Up
Post #153222 24th Nov 2012 9:05pm
ollielloyd
I thought so because it goes out after few seconds. If it was preheating car it would stay on.
Not sure why you can deactivate it though- why would you do that?
Post #153224 24th Nov 2012 9:11pm
mjdronfield
Just looked on a few BMW forums, and the general consensus is its the glow plugs pre heating. Some say it starts when you open the door, some say when you put the key in the ignition. Thats on later BM's though.
I now assume to "deactivate" it, you attempt to start the engine.............
I thought the curly orange coily glow plug light was enough, I always wait for that to go out anyway.
My FBH was running at the time, but that was probably a coincidence.
You learn something every day. Well nearly !!
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #153229 24th Nov 2012 9:16pm
