Home > In Car Electronics (L322) > HELP! cd stuck in changer |
tony1kenobee Member Since: 07 Jul 2012 Location: SOUTHAMPTON Posts: 145 |
hi all , just looking for some help.a cd has become lodged in the cd player (glovebox type)on a 2003 L322 model.does anyone know how to remove the cd player or know anyone who can.im in southampton.any help or pointers would be gratefully accepted.regards in advance
24th Nov 2012 2:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
hit it with a screwdriver ... ... - .- -.
24th Nov 2012 2:17pm |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 |
Hi Tony Had the same problem and it is a bit of a pain to get out as the holder is held in with two screws, you have to remove the glove box and also the passenger side end cap before you can get at the screws. see instruction in the link http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html You can then open up the cd changer and rewind the loader arm. I then used some good silicon grease to lubricate the arm. I left out the two retention screws as it is then so much easier to get it out if it sticks again. Mine now works a treat. Hope that helps Gary |
24th Nov 2012 3:15pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
had the same on my old car. As Stan says " hit it with a screwdriver " . May sound a bit harsh but it worked for me- it ejected straight away, was fine after that Paul
24th Nov 2012 3:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Can we just qualify:
24th Nov 2012 7:19pm |
Thank you all for your input.it seems as if a disc or the holder is stuck half way between the holder and the player.gonna have to take somewhere me thinks. Not that technically minded.ill keep you informed.just a quick question.can I replace the whole unit,if so any recommendations as to what I should replace it with .regards in advance.tony |
24th Nov 2012 7:30pm |
Unless you want to have a cd player (you probably have the one that only plays audio cds like me) it may be worth looking at the alternatives, e.g. mp3 player (one of those ipod things) that can be run from the screen (do you have a screen or mid unit?) .
25th Nov 2012 1:13am |
I have a screen with a tv.also iive had a DVD player and a free view box fitted.there is a USB stick port available.can I play my music through the screen with either of these?cheers tony |
25th Nov 2012 9:47am |
Hi Tony
25th Nov 2012 1:59pm |
Yep thats right. Had exactly the same problem with my old car and a sharp tap with a screwdriver handle while pressing the eject button and the magazine ejected no probs. Was fine after that Paul 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
25th Nov 2012 7:42pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If you slide the cover open so you can see the CD cassette, get a torch and shine it down the right hand side of the CD cassette. There's a gap between the CD cassette and the main changer body that will allow you to see which CD is stuck. Use a small electrical screwdriver and place the blade on the edge of the stuck CD holder and ease it back into the CD cassette, it will go back in by itself once free. I've had this a couple of times and it seems to be when the I've disconnected the battery. |
25th Nov 2012 9:48pm |
