![]() | Home > Maintenance & Mods (L322) > Air filter td6 |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
Hi everyone, I'm about to buy this filter http://www.ebay.co.uk/itm/Range-Rover-L322...0606159749
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
i cant see the benefit of paying that much for an air filter, just get a standard one it will work just as well....
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
The only way to get more air through a filter of a set size is to make the holes bigger. Then you have a few issues.
I tend to regard products such as this as snake oil till proven otherwise.
ah but I do not seek the performance, I'm just a filter with a lower maintenance and longer life ...... |
![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
I would go for the standard paper filters. To me the blurp sounds nice but I wonder the "environmental effects" are real once you do a cradle to cradle assessment.
I would say then it is better to replace with an original product every 10000/20000 more that the cleaning performance of a ...
The original filters are a foam type so i would say they have move area and better filtration due to the area covered by a foam surface.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Standard all the way with me too. Over the years tried pancake filters, K+N and have never noticed a differance...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I have a K&N which was fitted a year ago. Removed the EGR at the same time, so diffucult to say what resulted in a bit more bottom end torque, but there is definately more induction noise when you accelerate........
I am running a K&N as over here the original air filters are ridiculously expensive and the environment is quite dusty. So it is much cheaper for me to run a K&H. However since I now have a good line towards the main dealer in Holland and good transport to here (I travel to Holland regularly myself amongst others), it would have been easier to go paper filters again but will stick with the K&N filter for now, to see how it holds up here. MY 2010 5.0 SC Galway green and sand interior!!
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
K&N and similar 'filters' - or more correctly 'vegetable colanders' aren't much good apart fom keeping large insects and small birds out of your engine. When it comes to protecting your engine from dust, particularly finer stuff, they just don't cut it. Go the paper filter every time. If you don't believe me, hold one up to the sun - see all the holes - they keep |
Are the after market K&N type filters not sold on the "larger surface area" benefits of air flow ? So even if they had the same size holes as the paper elements, better air flow would still be achieved............
