Left hand side of the boot for corrosion and water. AFAIK the display button is direct mechanical and not ibus related, so this is an odd one, but may be affected by the bord monitor unit thinking tape eject has been requested. Problems most likely in the boot, but you may need to lift the dash panel to check connections to the bord monitor.
Just in case, eBay item number eBay Item No. 230885317026 .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
