![]() | Home > In Car Electronics (L322) > Help with Hybrid Digital Tuner |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 ![]() ![]() ![]() |
Managed to get my hand on a digital hybrid tuner (Par No 6 966 615 ) i already have an aftermarket DVB-T that uses the existing aerials so i know i can get a signal - fitted the new unit and have two problems.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
From a quick look on the web, that seems a part number for the hybrid tuner, so unless someones stuck a sticker on an analogue one..........
Thanks for your replies, i have had a look in the hidden menu and can not find anything regarding screen resolution.
Hi Gary,
Hi Steve
Pretty Sure you just need United Kingdom no need to mess with PAL settings. I had same issue with a unit in a car I thought was hybrid. Turned out to be analogue only....... |
I'm tempted to think that as you see the EPG, it ought to be a genuine hybrid unit......
Yes I see then it must be faulty I guess... |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Steve, I agree that the aux input is activated with the correct lead (which I had) but like all of the FFRR BM54 units there was a period when the BMW BM54 also didn't have aux input built into its software so even with the correct lead attached the aux option did not display on the monitor. By entering the hidden menu I was able to read the software version of this "rogue" BMW BM54 tuner which was older than the part number shown on the case. Hence in my instance I had older "guts" in a newer box ![]() Gary, frrom what you have said about seeing the EPG then you must have a hybrid unit and you can ignore my comments regarding an older unit in a newer box. The aerial connections on the tv tuner shouldn't make any difference but just to be sure you could try reversing them and as also already stated you only need to select UK for the freeview to work, no need to change the pal settings. Also try and find a nice high spot where you can park up and re-tune, hopefully then you wil pick up some stations and know all is working ok. ![]() Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
