Home > General > Help! Newbie Tyre Worries |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
Welcome!
17th Mar 2010 9:38pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
hi welcome
17th Mar 2010 9:42pm |
You can mix and match any size wheels and tyres from the FFRR models with no effect to speedo etc.
17th Mar 2010 9:48pm |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 |
Thanks for your thoughts guys - it's much appreciated.
17th Mar 2010 10:42pm |
Make sure they are 255/55 R19 anything else other than 255/50 R20 is not Standard LR fitments. |
18th Mar 2010 7:26am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
As someone else has alluded to, use the tactic I use with engineers on my aeroplane. If you think you may be getting fobbed off, e.g. 'that oil usage is fine and within the limits' but you suspect it is cack, I say 'OK just seemed a bit high to me, can you show me the manual where it states that burn rate is within limits and I'll take the jet.'
18th Mar 2010 8:39am |
Quick update. Rather than face the problem tomorrow, I called the dealer again today to try and finally put my mind at rest. I know I've been told that the tyres are the correct size, but I still can't get my head around that I wrote down 255/50 when I viewed the car. I can't shake the feeling that I'm being told what the correct answer should be, but that no one's actually looked at the car.
18th Mar 2010 5:44pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
a;so you CANNOT just change two tyres on an axle and then do the others when they wear out the FFRR is full time 4x4 and you could damage a part of the transmission due to different axle speeds , so being as you have differnt size to std youll need to change all four to the correct size and check the spare onto no6 Range Rover
18th Mar 2010 5:49pm |
OK, so it's the latter - they think I'm a complete lunatic!
19th Mar 2010 1:41pm |
Pictures! Discovery 4 HSE
20th Mar 2010 12:44pm |
Will do, but it's done nothing but chuck it down since I picked it up. Wating for a bit of sun and a quick clean up and I'll take a few snaps. I'll even take a few of the tyres! |
20th Mar 2010 8:41pm |
