Home > Maintenance & Mods (L322) > What's reasonable...? |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
Guys, asking for your opinion here on some work I have had to have done recently.
19th Nov 2012 12:36pm |
Sticking rear calipers is indeed a known problem (mainly in the S/Cs I thought but obviously not limited to them). What surprises me that it went unnoticed (or can you remember in hindsight some "strange" behaviour). When mine started acting up, I noticed it quite quickly. It was "holding back" after say 15/20 kms as it had fuel starvation. Also the left rear wheel gave of a lot of heat after a drive.
19th Nov 2012 2:43pm |
Thanks both for your opinions.
19th Nov 2012 3:34pm |
I would expect driving like Lewis would actually prevent you from noticing it as he is either on the throttle or the brakes with no idle periods inbetween
19th Nov 2012 3:44pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Yes its a very common issue with all (thus far) pre electronic handbrake FF's...
19th Nov 2012 8:57pm |
