![]() | Home > General > Newb thinking of buying an 03/04 V8 RR needs some advice |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
With the advent of the new model FF being out then maybe see if the jag-engined (facelifted) models are in your price range? They have a newer gearbox and a smoother engine apparently, which if you factor in the cost of a replacement gearbox it might work out similarly priced? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Gearboxes seem to pop around every 90K-120K and then every 90K-120K
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 ![]() ![]() ![]() |
craig-4.4 v8 gearbox.i thought it was mainly a problem with the td6 gm box not the petrol.is this the case?the reason i ask is i have an 05` plate bmw v8 with 107k miles on the clock.read loads on the forum pre-purchase on what to look for etc and took the plunge about 3 months ago.is it a case of WHEN not IF this box is gonna go?cant tell if box has been done due to lack of some service history but drives fine and no issues so far. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1424 ![]() ![]() |
They both have issues really ( i.e. if its going to go, then it'll most likely be because of ... ).
Colloggett Member Since: 18 Nov 2012 Location: Upstate New York Posts: 2 ![]() ![]() |
Thanks Guys. I'll take a look in more detail. |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
its worth bearing in mind all of the owners out there that do not come on these forums, and have never had a problem with the gearbox. I bought my L322 v8 with 140k on it and the 'box had lasted for 138k. MY2010 TDV8 Vogue Ipanema Sand
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
have to agree with woodchoppers post above.My 02' v8 has 114k on it and gearbox fine so far and I tow a lot with it.Changed gearbox oil cooler as it blocked up but box still holding up well and I change fluid and filter at regular intervals.this helps to prevent premature gearboxes and torque converters failure in my experience |
