Home > Technical (L322) > Parking sensor problem
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Hi guys looking for some info and help on this, recently my rear sensors have been beeping constantly when selecting reverse I had thought it may have been a sensor issue but after checking the four sensors all are clicking, the problem is intermittent but is a real pain in the a%#e when the problem occurs especially as my camera is on the bung also, could the problem lie with the parking sensor module?
Cheers stu F**K IT you only live once
Post #151806 18th Nov 2012 11:04am
Are you sure it's the rear and not the front? Previously..
Post #151808 18th Nov 2012 11:13am
stuboy00
Yea mate different beep from the front Wink also just to be sure I did check the fronts too Wink F**K IT you only live once
Post #151810 18th Nov 2012 11:19am
mjdronfield
Is this any use to you ?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151811 18th Nov 2012 11:23am
stuboy00
Cheers mjdronfield this looks like what the problem might be many thanks F**K IT you only live once
Post #151812 18th Nov 2012 11:26am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had the same problem last year.
I replaced the module with a used part from eBay for around £40.
Post #151827 18th Nov 2012 1:35pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Mine does much the same . One minute works properly then they stay on. Getting a bit sick of it as you never know when its going to happen. Usually just hit the off button
Gary
Post #153756 27th Nov 2012 12:04am
