Home > General > FF a bit misty inside this morning
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
looked out at my baby this morning and the front screen was misted/fogged up but looked like on the inside? could see swirl marks where id cleaned the screen a couple of days ago too
What causes the misting up on the inside?
Post #151794 18th Nov 2012 10:08am
Damp.. Previously..
Post #151795 18th Nov 2012 10:09am
Water leaking into the rear spare wheel area Shocked
Post #151799 18th Nov 2012 10:20am
Its the weather! I looked outside my front door last night and there are 4 customer owned FF's there, and five other cars and they were all as you described! If yours does not normally mist up then its just a weather thing...
Craig Rolling Eyes
Post #151800 18th Nov 2012 10:25am
As craig says it can be the weather, particularly when a period of warmer, more humid days changes overnight to very cold.
Simple condensation of the moisture contained in the car.
If it carries on each night it tends to suggest you have a bootfull of water. Smile
Post #151801 18th Nov 2012 10:32am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
If you have a heated windscreen it's nothing to worry about, if not a really thin layer of washing up liquid will stop it.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #151816 18th Nov 2012 11:50am
run with the a/c on, that should help dry the air in the car.. ... - .- -.
Post #151822 18th Nov 2012 12:19pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
[quote="47p2"]Water leaking into the rear spare wheel area Shocked[/quote]
This - check ASAP
Post #151837 18th Nov 2012 2:22pm
It sounds to me like the natural condensation you can get from the difference in temperature between the outside and inside.
I wouldn't think it was anything to worry about, even getting in and out with wet feet etc can make this happen.
I always run the car with the aircon on and mine has fogged up a bit on startup recently.
It's always worth checking the rear wheel well though. Discovery 4 HSE
Post #151839 18th Nov 2012 2:45pm
mrblonde
Cheers everyone, its fine in the summer (well, the 3 days of warm weather a year we get), and only happens when its like it was last night Rolling Eyes
sounds normal then, was worried might mean a dodgy door sela or something letting cold air in
Read elsewhere could be a blocked pollen filter, but this was changed 2 years ago (only do 3k a year), would it be worth changing that again?
Post #151873 18th Nov 2012 5:21pm
mrblonde
RR8701 wrote:
This - check ASAP
Will check first thing tomorrow just to be safe, cheers
Post #151875 18th Nov 2012 5:23pm
Mine was frozen all round first thing this morning Sad need to get the Vaseline in the door seals again Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #151939 18th Nov 2012 10:28pm
Turbo Tony
Treat your seals with this at winter time:
(no, it's not a link to raw fish! Rolling Eyes )
http://www.ebay.co.uk/itm/160900851437?ssP...1497.l2649 Researching my first Range Rover purchase
Post #152112 19th Nov 2012 6:09pm
I think this has been mentioned before hasn't it? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #152565 21st Nov 2012 2:32pm
many times but tbh a reminder is worth it cos its very good stuff and the fullfat does suffer from sticky doors.. ... - .- -.
Post #152570 21st Nov 2012 3:29pm
