Home > Technical (L322) > Problems after a full tank of diesel
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Hi all yesterday I happened episiodio a strange after doing the full I got home, I parked and after an hour I had to start again, turn the key and nothing but the sound coming from the immobilizer next to the gear lever, and nothing .....
the battery is new as well as all the relays that I put new for trouble.
could be the secondary pump? what kind of defect has when it has the problem? starter motor turns the same?
thanks in advance for your answers
Post #151328 15th Nov 2012 12:29pm
Mr Tee
Se pensate che la pompa del carburante secondario č difettoso, dare un colpetto con un martello e potrebbe iniziare a lavorare. Vale la pena di provare questo prima di iniziare a spendere pių soldi! Thumbs Up
Post #151357 15th Nov 2012 2:36pm
in english please Mr t, Wink
"If you think that the secondary fuel pump is defective, tap with a hammer and could begin working. It is worth to try this before you start spending more money!" ... - .- -.
Post #151358 15th Nov 2012 2:39pm
Mr Tee
what's the problem Stan??
Post #151359 15th Nov 2012 2:42pm
feel free to reply to the OP in italian by pm if you wish but for the benefit of the rest of the members ,please post in english.... ... - .- -.
Post #151361 15th Nov 2012 2:48pm
madcima
thanks, I'll try tonight, then I can start crying! Shocked
Post #151365 15th Nov 2012 3:06pm
madcima
in fact does not work ....
Post #151409 15th Nov 2012 7:22pm
