![]() | Home > Maintenance & Mods (L322) > rear brake pads |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
are the rear caliper pistons a squeeze back or squeeze and screw back just so im prepared for when i change my pads |
jope Member Since: 04 Apr 2009 Location: Reinsvoll Posts: 43 ![]() ![]() ![]() |
Squeeze back |
supurb |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Easy to do. Did mine a couple of weekends ago, all round. 3hrs total time inc removing/refitting wheels. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
You've bought handbrake shoes? You'll find you probably won't need them. They don't do anything apart from hold the car. Unless you do handbrake turns, they should be fine. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
the previous owner must of had a habbit of driving with it on as it has burnt the rear disc and now has no effect at all when used. but thought i would buy a set any way as when its all off i didnt want to find i need them. V8 facelift Range Rover Autobiography 22" wheels.
