Home > Maintenance & Mods (L322) > Swap Chrome Tubes for Side Steps Anyone?
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Not too sure if this should go in the FS/WTD (so apologies if I have it wrong), but I have a set of chrome side tubes fitted to my car at the moment. I want to get a set of side steps instead for my wee fella getting in and out (he's already complaining about slipping of them as he's used to the side steps on the P38).
If no swaps, then I'll just sell them.....anyone know what they're worth second hand?
Also, can anyone recommend a good set of side steps? Loads on eBay etc, but I'd like some recommendations from you guys.
M.
Post #150500 9th Nov 2012 9:49pm
Probably best with OEM ones , as there have been a couple of folk who have bought OEM style ones and the fittings are out by a few mm and don't line up correctly Thumbs Up
Post #150504 9th Nov 2012 10:17pm
ebajema
I have the OEM ones and my girls use them all the time. No slipping has occurred yet. MY 2010 5.0 SC Galway green and sand interior!!
Post #150519 10th Nov 2012 9:32am
mjdronfield
Would you not need to change the front mudflaps also ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #150520 10th Nov 2012 9:42am
Yeah he will have to do that also but i am sure the OEM ones come with the front flaps Thumbs Up
Post #150522 10th Nov 2012 10:25am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I've got a set of OEM ones that are sat in the garage. They have the mud flaps but don't have any bolts (had to cut them off to get the steps off). They have a couple of small dings on the underside but these aren't noticeable when they are on the car. You're welcome to them for £100 although posting them might be a nightmare as they are big and heavy.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #150524 10th Nov 2012 10:34am
Just get some rubber treads stuck to the tubes Smile Should be the best option for you Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #150540 10th Nov 2012 1:49pm
mjdronfield
Re the flaps, the OEM ones come with the front flaps, but the side tubes don't (AFAIK) so if you have OEM ones and swap for tubes, you will also need new front mudflaps. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #150542 10th Nov 2012 2:30pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I've been toying with the idea of chrome side bars instead of the steps that I have. We never use the steps as I'm 6ft2in & SWMBO is 5ft11in so getting into the car is not a problem.
My car is fitted with the standard mud flaps too but I'd hapily take them off.
I'm in east Ayrhsire if you'd like to take a look sometime.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #150546 10th Nov 2012 2:53pm
marcoos_1
Thanks guys.....I hadn't thought about the mudflaps. I should have remembered as I fitted them when I fitted the steps to the P38.
I have front mudflaps onmy car now..... so do I just swap these at the same time, as I'm assuming they are different?
M.
Post #150559 10th Nov 2012 4:46pm
mjdronfield
I would imagine you'd swap them with the tubes for the ones for the steps.
Otherwise the person having the tubes would be left without mudflaps and holes in the front arch liner thing.
Front mudflaps new OEM are about £55 all in I think, just for info. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #150562 10th Nov 2012 4:56pm
TheAllSeeingPie
The OEM ones bolt into the same place regardless of the recess for the steps or not. As I said I have OEM sidesteps and mud flaps sat in the garage if you're interested. All you'll need is some bolts from the hardware store (about 6-8 bolts for the steps, you can recycle your mud flaps bolts) and you'll be set.
Post #150616 10th Nov 2012 11:27pm
marcoos_1
Thanks guys.
PMs sent!
Post #150654 11th Nov 2012 2:38pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I'd like to jump on this topic too! I also have chrome tubes and would like to swap them for OEM steps or similar, as my dear old granny cannot get it without me having to help her up. Steps would be more convenient although I do prefer the tubes.
I could meet somebody if within reasonable distance to do a swap over. I dont think it would take 2 of us long at all.
Woodchopper MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153623 26th Nov 2012 1:37pm
marcoos_1
It's proving difficult....I PM'd the guys who replied but haven't been able to sort anything out yet.....not sure if they changed their minds.... Confused
There's no doubt the steps make life easier for the auld yins Wink the grip tape idea might be a good short term solution though.....
Post #153681 26th Nov 2012 8:26pm
