Home > Technical (L322) > iBus + Resler Interface + Navcoder |
For those interested, as you'll know a few months go I bought the Resler Interface. But I was moving house, then xmas happened etc so not had a real chance to have a play with it.
8th Mar 2010 10:01pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
Why would you want to do that? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Mar 2010 4:46pm |
Because it's the precursor to programming your own functionality and changing dealer spec options. |
9th Mar 2010 5:15pm |
oh, ok. Can i make my doors lock when I drive off using this then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Mar 2010 5:35pm |
Yes, if you can figure it out. |
9th Mar 2010 8:56pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I've just used the USB interface lead with Navcoder and sucesfully enabled tv in motion, had a bit of an issue with my laptop saying com3 was in use but managed to get round that. Seems like a good bit of kit. 2006 Mercedes CLS
17th Mar 2010 10:39pm |
Where did you take your iBus feed from in the end? |
17th Mar 2010 11:06pm |
Just plugged it in line with the TV Tuner, connected straight away once I got the laptop sorted. 2006 Mercedes CLS
17th Mar 2010 11:39pm |
Just remember next time you plug it in it should go into the same USB port, if you put it in a different one the system will assign it a new com number. Not a problem as long as you connect it all up and THEN open Navcoder it should auto detect which com port to use.
17th Mar 2010 11:41pm |
Yeah cool, I'll remember that. I'm gonna have a play around tomorrow after work. 2006 Mercedes CLS
17th Mar 2010 11:55pm |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 |
Ive just recieved the Resler Interface and paid for Navcoder and can I hell get it to work
26th Mar 2010 8:43am |
What wire are you using to get the iBus? CD Changer or in the boot? Describe the problem... |
26th Mar 2010 9:14am |
I have fitted an intravee and Alpine ipod controller so its easy enough to get to the ibus lead in the glovebox
26th Mar 2010 9:32am |
Are you using two wires or three?
26th Mar 2010 9:37am |
