Home > Maintenance & Mods (L322) > All dash display lights down...night driving with torch
mistajimbo
2005 Range Rover Vogue Td6 Java Black
having searched for a good while and now bamboozled by suggestions, I'm at my wits end. The dash lights and heater control lights have all stopped working. I'm just getting the pixel display at the bottom which will increase / decrease intensity with dimmer switch. had the headlight switch off and cleaned, checked wires behind steering wheel for breaks, even played with memory seats as suggested by someone.
has anyone else experienced this.? the lifghts didnt just suddenly stop working, they were intermittent for a few weeks before finally dying.
any help much appreciated.
Hello by the way Smile
05 l322
Post #150211 8th Nov 2012 1:28pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
They are controlled by the LCM (Lighting Control Module) - it's worth looking for error codes there. Also check all fuses (obvious!) and look for shorts - mine were out when I got the car, and the short was inside the passenger door at the front where the power goes to light up the LED in the interior door handle.
I would guess that the waterfall lights are also out!
Post #150212 8th Nov 2012 1:31pm
mistajimbo
Hi Simes
Thanks for that.... checked all fuses, they're fine, I think the waterfall lighting is still lit, can check that tonight. but that's interesting, a potential short in passenger door. Had a suspension issue last year and that was traced back to a short in the very same place !!
Post #150215 8th Nov 2012 1:51pm
Simes
There is no such thing as a coincidence!
I'd start my search there then!
Post #150216 8th Nov 2012 1:52pm
mistajimbo
OK will try there 1st. Just a quick one, I was under the impression that the LCM only controlled exterior lighting, am I well wrong ?
Post #150219 8th Nov 2012 2:03pm
Simes
Yes - it controls the exterior lighting - and everything associated with it. So the interior lights that come on with the exterior lights (Dashboard, door handles, waterfall etc) are all through it - I think the main interior lights (in the roof and boot) are also controlled by it.
Post #150220 8th Nov 2012 2:05pm
mistajimbo
Ok nice one, will see what we can make of it. Thanks for the advice
Post #150221 8th Nov 2012 2:07pm
Simes
Good luck - chances are it's a cheap fix (probably a bit of insulating tape!) but tracking it down can be a nightmare. The LCM is meant to control the current if there is a short, to stop the MOS-FET output transistors from frying - but I wouldn't drive around with out diagnosing the fault for too long...
Post #150223 8th Nov 2012 2:19pm
