Home > Technical (L322) > Getting heat sooner? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
If I leave the HVAC on automatic, it will take about 10 miles of driving on cold mornings before it starts blowing warm air. I have found, however, that if I start off with one of the selection buttons pressed (screen, footwells) then switch to automatic, I get heat after about a mile.
5th Nov 2012 8:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
never use auto tbh, i like to have it 'my way'.....did get caught by the side vents blowing cold till i realised my centre vent 'scroll' button was set on cold... ... - .- -.
5th Nov 2012 8:23am |
I just use park heat on these colder mornings! -1'c on bangernomics this morn!
5th Nov 2012 8:56am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
How do you find the temps without the viscous in place? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
5th Nov 2012 2:37pm |
Well it seems to warm up a bit quicker but not much else touch wood!
5th Nov 2012 2:40pm |
Have you used the hidden menus to see what temps your running and what you were before? I've been temped to do this but concerned with overheating issues. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
5th Nov 2012 2:51pm |
I may have used the hidden menu ages ago but not recently.
5th Nov 2012 2:57pm |
Having finished my journey to work with footwell and face level buttons pressed and turned off the car, I started my journey home in the same state some 9 hours later. 2 minutes into the ride home (at 30mph) I had lovely warm air coming out of the vents. Even better than the aforementioned button switcheroo. ONly a problem if the screen is misted up, but could try with the screen button pressed too, but aren't I just back to AUTO then ? .
8th Nov 2012 10:51pm |
maybe yes, but you are manually in control of the 'auto'..... ... - .- -. Y. O. L. O. . Last edited by stan on 9th Nov 2012 8:29am. Edited 1 time in total |
9th Nov 2012 8:09am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
9th Nov 2012 8:15am |
