![]() | Home > In Car Electronics (L322) > Luggage space lights not working |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Led's only work one way round, try swapping it round first to check, also put the old bulb back to check if you still have 12v |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Thanks for the reply. I've tried that and still no joy.
if the fuse is blowing then you may be shorting it as you put the lamp back in to place, try removing the fuse then install the led into the holder and into the car then replace the fuse, ive put leds's into my 2002 vogue and never had this issue |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
This happened to mine when I first put the LED's in. New fuse and battery disconnected for a couple of minutes sorted it. |
