Home > General > European travel requirements
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
evening all! just tabbing down to Morzine in France for a spot of schussing on the piste. have got most things - V5, insurance doc, warning triangle, hi-viz jkt, tow rope, jump leads etc . what else do I need to do/know? am I going to have to mask my lights at all? Can light bulbs be changed by oneself (if not then I don't need to carry spares!)
any guidance gladly taken on board.
Post #14949 16th Mar 2010 7:51pm
dan_uk_1984
If it's just France it's compulasary to carry a Warning Triangle and adjust your headlights - I think there is a lever for this behind the headlight housing.
Found this:
"if you have xenon headlights,undo the round cap where your hid bulb is and feel inside,there is a slide bracket that goes up and down,this is the switch to change your beam pattern to drive legaly on the right side in europe"
AA has some usefull info: http://www.aaroadwatch.ie/eumotoring/compulsary.asp
Post #14960 16th Mar 2010 8:35pm
Dolphinboy
Dan, as ever ...you are the MAN!!
Post #14962 16th Mar 2010 8:58pm
dan_uk_1984
Always a pleasure, thanks for the beer by the way! Always appreciated Thumbs Up
Post #14964 16th Mar 2010 9:02pm
You need a Hi-Vis for each person in the car not just one.
Le Flick do like to stop Le Roastbeef and Hand out fines. Evil or Very Mad 2008 MY Supercharged
Post #14973 16th Mar 2010 10:10pm
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
Found this:
We always get strange looks on the Channel Tunnel when we do this!
Post #14985 17th Mar 2010 8:01am
Yes, I got told off by a chinese french lady, probably because I was standing inbetween the cars when we were in motion. It takes about 5 seconds to do each one, the little slider doesn't feel like its doing much but I didn't get flashed by angry drivers while I was there!
I went down to the Grand Massif area in January when there was snow in the UK too, we had snow chains on board but never needed them, the frogs keep the roads clear. Discovery 4 HSE
Post #14990 17th Mar 2010 9:25am
I just blinded hundred of Frogs on my way to Morzine & Back as I did not know about the lever Rolling with laughter
Post #14995 17th Mar 2010 9:45am
ukrangie
I did the same last year driving up to Lille but that was more cause I didn't care. By the time we got off the ferry, it was really late so I doubt the rozzers were around.
Post #15106 18th Mar 2010 9:15pm
Dolphinboy
well, what a great way to go skiing. definitely not flying from now on!! left after work at 5 on
weds and arrived for breakfast at 6am thurs - 800 miles total. I drove over 8 hours in total (other half did 2) and averaged 26 mpg mixed driving. car cruised all night at 85 mph/3000 rpm without a murmur. sun is beaming down and snow is good but melting fast!! new snow next week apparently. I am in RR heaven!
Post #15181 19th Mar 2010 10:24pm
dan_uk_1984
New EAS pump happy?
Post #15184 19th Mar 2010 10:57pm
Dolphinboy
Purring like a baby
Post #15231 21st Mar 2010 11:59am
