Home > Technical (L322) > Switch beneath the steering column
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Thank you! My God, that's a full size loudspeaker! There is no bong thing in mine and no wire loose so they must have relocated the damn thing because it's bonging on every occasion and especially every time it's 4 deg. Celsius and this happens a lot these days and my heart goes wild every time...
Post #14926 16th Mar 2010 11:30am
dan_uk_1984
As you say, I imagine they relocated it. I was amazed to see how many wires then need to have going into it to make it bong!
As soon as I plugged the it back in, Bong door open, Bong key in ign, Bong check brake pads
Post #14927 16th Mar 2010 11:33am
adara
Being so easily accessible one could be tempted to unplug it, probably that's why they hid it somewhere else...
Post #14928 16th Mar 2010 11:36am
adigorn
hello everyone who has the switch under the column active
i mean u press it and lights come on on the dash
had the PDI caried out unproperly
the switch should be deactivated by removing the transportation fuse
so if it still works viva la stealers
Post #15039 18th Mar 2010 12:37am
