Home > Technical (L322) > Gearbox Wont Change Up |
Nickandtacita Member Since: 27 Sep 2012 Location: Bridgnorth Posts: 13 |
Hi, I wonder if anyone could offer some advice, This morning the box would not change out of 3rd, i was on the motorway so stopped at the next services, turned off, back on, all seemed ok.
31st Oct 2012 7:14pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Your transmission ECU is trying to protect your transmission from the fluid overheating by inhibiting upshifts to keep the engine speed (& therefore the flow rate from the transmission oil pump) high.
31st Oct 2012 10:29pm |
Hi Phil
1st Nov 2012 7:28am |
If you have one of those cheap digital IR temperature laser guns you could check the temperature of the metal sump pan at normal operating conditions. The fluid should level out at around 100-110 deg.C (similar to the engine coolant). If it’s reaching 130 deg.C + then you have a problem in the cooling circuit. If it’s not the radiator causing it you should suspect the transmission cooler itself next.
1st Nov 2012 11:37am |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 174 |
I had similar problems earlier this year, where everything would be fine and without warning it would downshift to third and then second. Despite letting it re-boot repeatedly it kept happening. I sent to a local transmission specialist who drained the oil, took the sump off and removed & cleaned the valve block. He reported to me that the gearbox had insufficient oil in, about half the recommended capacity. since then it has only done this once - this is since July. it sounds very similar to me. I just got back from an auto gearbox specialist having had the current problems (cattle grid judder etc) diagnosed - need a new torque converter etc!! these cars are fantastic, but expensive when they go wrong! best of luck but I would have the oil levels checked at least. |
1st Nov 2012 2:08pm |
Update:
2nd Nov 2012 3:40pm |
Problem not solved, oil temp up to 143 Deg C after driving for 20 miles, next stop, oil cooler |
3rd Nov 2012 1:10pm |
New oil cooler fitted, larger than standard, and independant of the engine cooling system.
20th Nov 2012 6:48pm |
You should not have replaced oil cooler without getting the radweld out of the entire system under pressure. Only other solution is to replace Main Radiator, Oil Cooler & all pipes as RADWELD is a to get out. You probably had a partially blocked radiator anyway and the readweld would have just cemented it in.
20th Nov 2012 7:09pm |
The Oil Cooler is Water Cooled via the Main Radiator how can your new one be independent of the engine cooling system? |
20th Nov 2012 7:12pm |
Thanks for the reply
20th Nov 2012 7:16pm |
So everything (Rad, Pipes, Cooler) was replaced AFTER the Radweld incident?
20th Nov 2012 8:01pm |
No Just the rad and the coolant manifold, i will make some calls tomorrow |
20th Nov 2012 8:14pm |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Someone one one of the forums had the same problem and he changed all of the cooling componants, raditator , oil cooler. He never thought to check the 2 pipes from the transmission to the oil cooler. Eventually he got around to changing these two pipes, and this solved the problem. MY2010 TDV8 Vogue Ipanema Sand
24th Nov 2012 9:31am |
