Home > Technical (L322) > How do I remove interior door handles?
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I've been working away tonight and experimenting with some carbon fibre wrap for the wood parts inside the car. I've never done it before, but I'm slowly getting the hang of it. To be honest, the hardest part was stripping it all down.
Can anyone tell me how to remove the silver parts on the door handles, not the actual metal pull parts, but the plastic parts with the crappy silver paint that always seems to come off. Do I need to take the full door card off, or can I clip it off from the front. I don't want to just rush in and snap any brackets etc.
Mark.
Car is 05/06 TD6.
Post #148878 29th Oct 2012 9:10pm
fisha
it'll be a door card off, then the handle will be held from the other side of the door card.
the door card is not difficult to remove ... takes a couple of minutes.
tricky part is refitting the trim seal along the top which touches the window. V8 or else ...
Post #148890 29th Oct 2012 9:56pm
marcoos_1
Thanks Fisha,
Much appreciated.
Back out to the garage for me now!
Mark.
Post #148893 29th Oct 2012 10:14pm
marcoos_1
Has anyone tried the Powerful UK black plastic parts wihich fit over the interior parts? Any good?
Mark.
Post #148896 29th Oct 2012 10:33pm
daveym
United Arab Emirates
If its just the door handle surround ( silver plastic type) then they just pull off. No need to remove door card.
Post #148899 29th Oct 2012 11:08pm
marcoos_1
Yeah, it's just the plastic surround that's painted in that really cheap looking mat-silver.
So I just lever around the edges and pull? I hate doing these types of parts......
Post #148903 30th Oct 2012 6:57am
daveym
Yep - I used a small flat bladed screwdriver to get some purchase and then with fingers pull gently. I started at the thin end and worked my way around each clip.
The first time is nerve racking but then it gets easier.
Post #149014 30th Oct 2012 9:50pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Yes they just pull off, no need to remove door card. There is video on powerful uk website. Search for replacement part and its there showing you how to remove. Just screwdriver to start them they pull of. Minute a door.
Post #149023 30th Oct 2012 11:31pm
marcoos_1
Thanks guys....I know what you mean about nerve wracking...I had a pry last night, but gave up as I had a vision of it all just cracking and breaking. I'll check out the video now.
Mark.
Post #149042 31st Oct 2012 9:24am
