Home > In Car Electronics (L322) > tv tuner
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
tv tuner
Has any body got a wiring colour diagram for the blue plug from the tv tuner.on a 2004 range rover L322 cheers Thumbs Up
Post #148574 27th Oct 2012 10:35pm
These are the two connection plugs for the tv tuner.
Not sure which is the blue one but you should be able to work it out from the cable colours.
Post #148597 28th Oct 2012 9:40am
reynolds
thanks for help what i need is the layout of the wires in the blue plug as i took the plug apart to clean the terminals and i want to check that i have got them in there right places
Post #148621 28th Oct 2012 12:22pm
Ah....!
The wiring diagrams won't be any use then. Smile
Post #148622 28th Oct 2012 12:25pm
reynolds
it seems complicted to me thanks anyway Barry
Post #148625 28th Oct 2012 12:42pm
It's raining today but if it clears up tomorrow I'll have a look for you and see if I can help.
I take it we are talking non-touch screen?
Post #148627 28th Oct 2012 12:46pm
reynolds
yes thanks in advance Thumbs Up
Post #148653 28th Oct 2012 3:19pm
mjdronfield
The pin numbers are on the diagram if it helps........
for eg...
C0825-14 is pin 14.........
Obviously it doesn't get you totally out of the woods, but may be a start...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #148686 28th Oct 2012 6:07pm
reynolds
thank you Thumbs Up
Post #148741 29th Oct 2012 7:21am
This should help you,
Tv Tuner Blue Plug Wiring
Front of Car
Top view of Plug looking down from boot
O Red / Green O Brown
O Blank O Blank
O White / Grey O Brown / Red
O Blank O Blank
O Black O Black
O Black O Black
O Black O Black
O Blank O Blank
O Yellow / Red O Yellow / Brown
Rear of car
Post #148776 29th Oct 2012 10:47am
reynolds
thanks great help Thumbs Up Thumbs Up Thumbs Up
Post #148787 29th Oct 2012 11:57am
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Hi,
Does anyone have the same info for the white t.v. plug? Thanks,
Amy
Post #334804 28th Jun 2015 8:25am
