![]() | Home > Technical (L322) > Cable routing |
???? It plays on the front screen anyway unless your driving..... |
ebajema's car is US spec and doesn't have that part of the loom. 2008 MY Supercharged
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Buy a UK loom part? From a breaker if lots new from Land Rover...
Hi Craig, I already have the cable (in the post right now) and I just want to add it to the existing loom. I would like to know what the best "route" is for that cable is, i.e. easiest to install. What would you recommend ? MY 2010 5.0 SC Galway green and sand interior!!
Straight down the sill, trip is easy to remove and underneith the silver SC sill plates there is lots of space to cable tie it to the other looms... All quite straight forward...
That's what I was hoping for !! Thanks Craig !! MY 2010 5.0 SC Galway green and sand interior!!
Yep, mine is a NAS and therefore misses the physical cable the connects the DVD player to the front screen. I have enabled everything with the Faultmate so that is not the issue. Also the headlights, although it has cornering lights, it misses the wire in the loom to actually switch the cornering lights on ![]() Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
Only 30% of 06MY> cornering lights work in the UK so your not alone...
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
That's what I said ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
+1, mine don't work - do you reckon it's the ECU at fault ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
