Home > Technical (L322) > New to forum -Battery problems and Air Suspension Inactive. |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 |
Hello,
26th Oct 2012 4:56pm |
Sounds like you have a leak in the air bag |
26th Oct 2012 5:06pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
As mentioned, sounds like an air bag. If you're handy with the spanners, there is a good 'how to' in the wiki, and it isn't a hard job. Parts will run to about £220 per side - do them both at the same time. You're battery also sounds like it is on the way out, which can cause all sorts of errors and faults. The beeping sound is probably the reminder that you have an active fault that needs attention.
28th Oct 2012 12:43am |
Cheers Gav,
29th Oct 2012 2:32pm |
