Home > Maintenance & Mods (L322) > Loud tapping/knocking noise :( |
Has your car had the drive shaft modification done ?? Or are you sure it is engine related and not drive train ? MY 2010 5.0 SC Galway green and sand interior!!
26th Oct 2012 8:05am |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
Hi GBWC
7th Feb 2013 3:55pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
hi, first post, so here goes, i'm currently in the middle of a m62tu44 timing chain replacement. (was looking for timing chain success stories)
23rd Feb 2013 1:02am |
GBWC Member Since: 13 Mar 2012 Location: Essex Posts: 20 |
Hi Paul, Yes, unfortunately (as above) it was indeed the timing chain guides. £750 in parts plus if I remember correctly 16 hrs fitting (dont quote me). If you have the same thing, STOP DRIVING IT NOW my mechanic rang me to say if I had ran it any longer it was game over for the engine. (I literally drove 10 minutes home when I started hearing the knocking, then another 15 minutes to his garage). On the plus side the whole front of my engine is new. |
26th Feb 2013 5:45pm |
just to follow up, i completed the timing chain/guides job and the engine is purring. -so quiet!
13th Apr 2013 3:11pm |
Alun1976 Member Since: 12 Oct 2015 Location: merseyside Posts: 10 |
Hi,
7th Feb 2016 11:29pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Have you looked at the how to guide on beisan systems which is where I would have purchased seals from ?
8th Feb 2016 6:52am |
Yes, followed besian guide to a tee, but every time I push the centre shaft back in the Teflon seal just comes off the O-ring. I tried so many times yesterday to do this, making sure the o-ring and the Teflon seal are free from oil and also the land free from oil, and just oiling the centre shaft piston and smearing the surface of the seal. I bought the seals from i6automotive as I have rebuilt another vanos for a M54 engine using their seals and didn't have any problems.
8th Feb 2016 8:42am |
Hi, I did mine a couple of years back, are you saying that as you insert the gear, it squashes the square edge seal out? Or the round o ring ? If so, I wonder if your gear has a nick in its edge, and if it could be checked or the edge sanded. If it has a very harsh edge, maybe this is causing it to happen. I think I struggled a little, but was trying hard to take my time, on a clear bench, with a magnifiying lamp. A couple of goes and I was in. Then I had to twist it a couple of times etc. Then I had to do the lip crushing excersize. The write up is very good, and I think I do remember contacting them, to ask something similar to you etc. As I could not quite grasp what I was trying to do with the seals. |
8th Feb 2016 9:09am |
Have you tried contacting i6 as i have spoken to them in the past when considering doing the job? |
8th Feb 2016 9:20am |
Yes ive spoke to i6, they have sent me out a second set of seals but he feels that the Teflon seal may be from a bad batch and too thick. They said that the rest of them he has in stock are probably the same as they were made in batches. So he has also given me a full refund.
8th Feb 2016 9:10pm |
If it's the same are you going to order on Beisan ? |
8th Feb 2016 9:36pm |
I bought mine from besian , in USA. 2 years ago. |
8th Feb 2016 10:42pm |
I was thinking of grinding a taper on the end of Helical gear shaft to aid installation but decided against this as it would likely through it out of balance (of that is actually critical, shaft must be orientated in its original position when reassembling ). The square edge teflon seal just pushes straight off the o-ring. Did you buy from i6 or besian? i6 have now removed their m62 vanos seals off the shelf. |
8th Feb 2016 10:44pm |
