![]() | Home > Technical (L322) > Adaptive lighting |
Paulo Member Since: 28 Sep 2010 Location: Glasgow Posts: 199 ![]() ![]() |
Have someone turn the steering wheel from full lock left to right and see if the beam of your headlights also moves.... |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Go out in the dark and put your lights on before you start the engine and watch it go cross eyed as the the self test is done when you start the engine 56 TDV8 Vogue SE
As Andy_J said but also you will have extra bulbs next to your side light bulbs and at night when you turn the wheel you will see thees light up to illuminate the inside of the corner. 2008 MY Supercharged
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
I really miss the adaptive lighting on my 2012. Wondering how much work is involved to upgrade. Anyone with the knowledge? 2019 D5 HSE Lux SDV6 Indus
