Home > Technical (L322) > Wind noise at speed from around windscreen..
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi, i wonder if anyone can help, ive noticed a bit of a wind noise coming from what seems like the back of the dash/bottom of windscreen area when at speed (over 50mph) does anyone know where this could be coming from? also ive noticed when the bonnet is lifted to the back of the engine where the scuttle panel is there are 3 tabs sticking up, are these meant to be like this? or has my scuttle been possibly removed and not put back correctly. Thanks
Post #147935 24th Oct 2012 7:14pm
Googsy
correct it's not fitted properly same issue on mine I removed and used a little black sealant job done noise gone. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #147944 24th Oct 2012 8:18pm
mjdronfield
i had that. its the plastic scuttle panel under the wipers vibrating.
there is a bead of sealant full width that can get disturbed. I pressed it down etc and eventually it stopped.
could also be the A Pillar finishers , but doubt it
tape the glass to the scuttle at the bottom of the screen and see if it resolves the issue.
Tabs sound OK, bonnet seal drops in there........... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #147946 24th Oct 2012 8:20pm
mjdronfield
sorry - on ps3 so typing takes 400 years !
googsy2 beat me to it .............. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #147948 24th Oct 2012 8:23pm
Googsy
Thumbs Up well at least I didn't repeat myself for once hanks to triple posting when using phone.. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #147955 24th Oct 2012 8:51pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #147957 24th Oct 2012 8:52pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #147958 24th Oct 2012 8:56pm
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Guys another thin to check is the AIR CON.
I thought for days I had a wind noise until I turned my air con fan off, then I realised it was just the wind noise coming out of the Screen Vents.
It only has to be on fan level 2 to make a noise.
And if you have your air con on Auto mode, it moves around from feet to face to demist vents and that can definately make a noise you're thinking is coming from the outside. L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #147970 25th Oct 2012 12:16am
JPS
Thanks guys, at the weekend i shall remove the scuttle and see if i can fix it. Its not the A/C as i did wonder that myself and made sure everything was off when i checked for the noise. Thanks
Post #147977 25th Oct 2012 7:30am
mjdronfield
Removing the scuttle and placing some more silicone sealant along it and putting back will fix it once and for all, but I just pressed mine down and jiggled it about (!!) and eventually the noise stopped. So you don't have to remove the whole thing if you are lucky.
I have also read that the plastic distorts over time, and fitting a new scuttle also cures it, but I'd imagine it would, as the sealant will have been redone.....
Its much better without that wind noise. Was a bit embarassing when I first got the car, and people wanted a ride in it !!
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #147979 25th Oct 2012 7:39am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
[quote="mjdronfield"]
quote]
One of my A Pillar finishers is a bit loose, which causes a noise - any helpful hints/tips to sort this?
Cheers! l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #148023 25th Oct 2012 12:19pm
mjdronfield
I just replaced the clips that hold it on. You can get to them when the front door is open.
Some of the old ones (back bit) do tend to drop down into the frame of the car though.........not an issue. You can't hear rattling from them or anything. Just a heads up.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #148044 25th Oct 2012 1:26pm
T111RDY
Cheers! Thumbs Up l:OolΞΞΞΞΞΞloO:l
Post #148763 29th Oct 2012 9:44am
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Must check mine as I had the windscreen replaced a couple of weeks ago & now it's making a hell of a racket at about 60-70 MPH. Range Rover 4.4 V8 Vogue
Post #150604 10th Nov 2012 9:34pm
