![]() | Home > General > A bit confused now..... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Start using fuelly.com (see my sig - you can click on the image to go there) to monitor your fuel usage and mileage. A test on one tankful is probably not enough to get a consistent reading.
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 ![]() ![]() ![]() |
Still a tad concerned that the OBC can apparently be over 10% optimistic!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
fill tank to brim, reset the mpg computer and drive, when you have reached a quarter tank ,refill and do a calculation..it should be the same'ish as the mpg readout..
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
The OBC MPG display can be calibrated to get it to display the correct figure...
what the feck does all that mean Simon.. |
It means when you're selling it, you can adjust it to show you get 45mpg... |
