Home > Maintenance & Mods (L322) > Water free coolant |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Saw this stuff on Wheeler Dealers the other evening...
19th Oct 2012 12:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
i saw that as well and if you can flush the system properly then its a good option..
19th Oct 2012 2:08pm |
Just wondered if anyone else has tried it - looking at the costs, it won't be a lot more than the cost of the proper anti-freeze for these cars - and that needs changing regularly. |
19th Oct 2012 2:19pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
When I was at Car Fest North in September they had a huge stand about this, I didn't understand at the time what it was about. Looked a faff to flush everything properly though. If your coolant has the right corrosion inhibitors it shouldn't be a problem though, especially in the UK.
19th Oct 2012 3:03pm |
Even engines run on the right stuff for 20years will have deposits in the system as the only way around it is using pure water, ie de-ionized type stuff normally for irons as its got little impurities left in it to react with.
19th Oct 2012 3:39pm |
£65 for 5 litres!!
19th Oct 2012 3:43pm |
19th Oct 2012 4:04pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Caterpillar have a similar product for all their engines. Might be a cheaper way of doing it or check out other large motor manufacturers to see what they use.
25th Oct 2012 11:32pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1302 |
Is there not a balance though regarding pressure. I thought the idea of running a pressured system was that it helped to push the coolant against the sides of the engine to get a better contact and thus better thermal energy transfer? V8 or else ... |
26th Oct 2012 6:59am |
Possibly, but the main benefit of running under pressure is to increase the temp at which the water boils FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Oct 2012 10:14am |
PDB Member Since: 04 Oct 2012 Location: Lutterworth Posts: 15 |
There is a similar discussion on another forum and one of the members found the follow:
4th Nov 2012 6:11pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
That never get mentioned on Wheeler Dealers.................
4th Nov 2012 8:48pm |
