Home > Technical (L322) > Is V-Power Diesel worth it for a TDV8?
JW911
I acquired a 2007 3.6 TDV8 Vogue this morning. Has anyone noticed any benefit from using V-Power diesel in theirs?
I'd rather put the regular stuff in if not. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #145801 10th Oct 2012 12:39pm
A1GSS
I tried one tankful, no noticeable difference in my consumption. Might possibly have been slightly smoother,but that's not definitive. Extra 8 quid a tank Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #145803 10th Oct 2012 12:55pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Same here,tried it last week , no difference. 2011 4.4 TdV8 Nara Bronze
Post #146527 15th Oct 2012 9:53pm
Unlikely to make much performance difference as the engined is tuned to the 95 Octane but it will make a difference to the MPG long term and should improve long term wear and keep the injectors clean due to the additives.
Post #146529 15th Oct 2012 10:24pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
This is diesel - cetane not octane (and not 95!). A higher cetane number means shorter ignition delay and (in theory) more complete combustion of the fuel leading to increased power, economy and smoother running.
Presumably most "premium" diesel also has some blend of additives in it to clean injectors etc. Can't say I've noticed any obvious difference in performance or economy on the odd occasion I've put it in.
Post #146530 15th Oct 2012 10:39pm
It was late and was thinking Petrol but you know what I meant....
Post #146537 16th Oct 2012 6:02am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
In the past I've used an additive, which is designed to clean injectors and boost the cetane rating of the diesel.
I just put it in the tank as I've pulled up at the pump before a fill-up, ensuring a good mixture.
No noticeable difference in MPG or performance but I did feel like I was pro-actively doing something towards maintenance.
Maybe placebo, who knows. I haven't put any in the FF yet but will be giving it a try at some point.
Can't remember the brand, but it is a well known one. Works out about the same in cost as buying the premium fuel at the pump, but generally only bother once every 4-5 tanks.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #146540 16th Oct 2012 6:54am
ebajema
I think if you use a "premium" fuel or additive, it will take a while to see the effect. First of all the cleaning of the fuel system and sometimes even cylinders/exhaust takes a while. I would expect it to show a difference after a few tanks (say 3 to 4) of continuous running on premium fuel, depending on the age of the car. It takes a bit of time to clean the fuel system and engine.
Whether it is placebo effect or not, my feeling is, if you use premium fuel or engine oil etc. you extend the life ot the components. So it makes sense if you plan to drive the car for a long time. If you trade them in every few years or don't do a lot of miles, the benefits will be limited anyway. I feel good maintenance is another factor in the equation as well, regular good maintenance can make a big difference in the "longevity" of a car as well as fuel consumption and smooth running. MY 2010 5.0 SC Galway green and sand interior!!
Post #146551 16th Oct 2012 7:44am
JW911
I've decided to run it on V-Power for the first few tanks to flush the system through and then revert to the regular stuff.
I averaged 29 mpg on the first tank (actual - indicated said 31.6!!) which gives 600+ miles range and I'd be surprised to see much improvement over that, although it would be nice to see 30 just for psychological purposes. 2021 3.0 P400 Vogue
Post #146556 16th Oct 2012 7:57am
T24RES
I'd be pleased to see anything over 25mpg Rolling Eyes
Post #146580 16th Oct 2012 11:45am
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I'd take 19 mpg... Laughing Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #146586 16th Oct 2012 12:24pm
JW911
The last one did 17mpg with the wind behind it. Embarassed 2021 3.0 P400 Vogue
Post #146613 16th Oct 2012 2:04pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
They do vary a bit then, mine hovers around 27mpg, and I do mostly steady motorway driving. Happy enough with that as thats what I was getting before from the Touareg but 30mpg would be brilliant... how in God's name do you get it to do that!? Bow down Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #146617 16th Oct 2012 2:24pm
Vogue
the only difference I noticed was in my wallet Confused
Post #146638 16th Oct 2012 6:57pm
