Home > Maintenance & Mods (L322) > Sunroof drain tubes
Sunroof drain tubes
Ok so this morning I came out to the car and noticed the pax footwell a bit damp. Quickly tracked it down to the pax side sunroof drain. I've tried boiling water, strummer wire, the usual but can get any more than 10cm down the holes on either the pax or drivers side. The drivers side is clear and runs free. Has anyone tried a drain unblocked like mr muscle? Does anyone have a picture of the routing to try and help with prodding stuff down there? Are there any one way valves and if so where? What are the drains made out of? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146253 13th Oct 2012 4:28pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
One trick that I have used on blocked pipes, is to put a flexible cable, like a bowden cable in a drill. Then, on low rpm's, let it dig through the blockage. Bend the tip on the cable for better efficiency. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #146312 14th Oct 2012 7:57am
Sorted the drain today. Took all of 2 mins as well. The drain comes out about middle of the door, in a rubber cone. I couldn't manage to feed anything from the top to bottom so started at the bottom. Used a bike cable to start at the bottom. Pulled the valve out of the chassis and within a few wiggles had water pouring out. Used some bleach and boiling water to flush and runs like a gooden now. Will post pics later to show exit points.
Bottom of the pic is the front of the car. Just behind the passenger wheel arch
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146505 15th Oct 2012 6:44pm
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Are these pics taken behind the air vents on the back of the wing? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169725 3rd Feb 2013 1:26pm
There under the car. About middle of the door. You can see a recess where the brake lines and fuel lines run. It's in the recess there. One either side of the car.
Edit: the left side of the pic is the left chassis section. If that helps locate it. Also nothing needs to be removed to gain access. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #169938 4th Feb 2013 10:46am
Paulhh
Got it, cheers for that. I just couldn't make out the photo at first 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #170399 5th Feb 2013 11:10pm
