Home > Technical (L322) > Webasto FBH fault code glow plug sensor short to ground |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Yes the pumps starts after about 25 to 30 seconds and clicks/pluses every 1.5 seconds
3rd Oct 2012 3:36pm |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 |
Hi again
3rd Oct 2012 9:47pm |
Yes they are
4th Oct 2012 7:18am |
Well after all the planning and research i was going to start my diagnostics this weekend.......
6th Oct 2012 2:09pm |
An update - still not fixed yet
12th Oct 2012 1:24pm |
webasto Thermo Top Troubleshooting Tree pdf
12th Oct 2012 3:37pm |
Thanks Steve
13th Oct 2012 12:04am |
Hi Aurrian
14th Oct 2012 3:23pm |
Thanks guys.
14th Oct 2012 8:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Hi guys,
19th Oct 2012 7:56pm |
Webo Member Since: 20 Oct 2012 Location: London Posts: 1 |
Hi guys, I found this tread whilst looking for something else so thought I'd stick my oar in. I am a factory trained Webasto, Mikuni & Wallas heating tech and Advanced marine Electronics Tech, though my business is marine based, the TTV is operationally similar to a TTC with ECU mods and sometimes (when used as an auxiliary rather than a pre heater, without a water pump. The advice given so far has been accurate but one thing, the fault codes though a guide should not be relied on as absolute and can be misleading, I use a Thermotest diagnostic laptop which is specific to the heaters and the sensor readings often do not relate to the actual code. The main reason for faults on these things is poor installs (not applicable to factory option units) I have nothing to add to the specific diagnosis as it has been almost certainly narrowed to the circulation pump, these units check all parameters before starting so would not even try with a faulty pump. The best advice I can give to people who have these fitted is to run them at least once a month even in summer, this helps prevent seized bearings, pump vanes etc and ensures that the dosing pump and lines have fairly fresh diesel in them too, they are only 2mm ID and can easily block and the pump can stick indicating an expensive fault when all it needs is a "Whack". Last point, earlier in the thread somebody mentioned applying 12vDC direct to the glow pin, be very careful when doing this and never more than briefly, The ECU actually pulses the power and direct application can damage the glow pin if allowed to remain more than a few seconds.
20th Oct 2012 9:00am |
thanks webo!
20th Oct 2012 7:42pm |
I have just had a bit of a fiddle this morning, arch liner out, tried to run it.
21st Oct 2012 9:50am |
Final (hopefully) update.
26th Oct 2012 6:08pm |
