Home > Technical (L322) > Brake fluid change
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Brake fluid change
Car booked in to have brake fluid changed tomorrow
as I've had the car 2 and a half years
And can't see it done in the LR service book Sad
Anything to look out for before I drop it off to a standard garage Neutral RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #145651 9th Oct 2012 8:20pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
check the spec on this and make sure what they are going to use is the correct DOT fluid Razz
Post #145693 9th Oct 2012 10:07pm
Jr-auto-electrics
Which is???
Dot 4 I think RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #145694 9th Oct 2012 10:08pm
simonmanx
yes 4 Thumbs Up
Post #145695 9th Oct 2012 10:14pm
csjxx
United Kingdom 2004 Range Rover Vogue 4.4 V8 Zermatt Silver
Any idea of the quantity needed?
Post #145769 10th Oct 2012 11:00am
Jr-auto-electrics
Brake fluid changed baring the drivers rear
As the bleed nipple is rusted tight shut and they were scared they would break it off
But it's made a great improvement to the brakes
I now have to put less pressure on the pedal
To stop the tank Very Happy RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #145914 11th Oct 2012 7:54am
A little heat around the seized nipple and tighten it up slightly before loosening it Thumbs Up
Post #145933 11th Oct 2012 9:12am
ebajema
maybe also a good time to consider replacing the rear calipers before they seize up (although that seems to be more S/C related that Td6). The calipers are quite cheap and it will ensure you won't have any problems in the future. MY 2010 5.0 SC Galway green and sand interior!!
Post #145938 11th Oct 2012 9:36am
The TD6 rear calipers do also tend to sieze Big Cry
Post #145941 11th Oct 2012 10:02am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
That's very true, I changed my rear callipers last year (TD6). Not a big job really though. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #146045 11th Oct 2012 11:30pm
