No chance I'm afraid John I'm well f'd off with it now!
I got the mud shields off(actually mud collectors!!!)
Then the heat shield came off with the above.
Then the spare wheel cover came out
then rear seats up
Then the carpet under said seats folded back, another fun task!
Then the 4 nuts off the covers
Then the spin rings off
Then pass side is just a blank
The drivers side however won't lift out once you slide the electro plug up and left and then pull the slip rings on each pipe UP as you gently pull that pipe up.
One however uses the gay connector so needs wangling off and replacing.
That's tonight's work done! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
