Home > Technical (L322) > Auxiliary Heating |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7821 |
I believe all diesels have it.
6th Oct 2012 8:28pm |
ikilla2 Member Since: 22 Jul 2012 Location: England Posts: 72 |
I have an 03 td6 hse, when I unlock the the car and open the door it sounds like a boiler ignites in the engine bay and continues for about 15 minutes - is this the aux heater? |
6th Oct 2012 8:32pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
My car did that when I bought it and the FBH didn't work
6th Oct 2012 8:41pm |
No, that is the ECU fan in the engine bay wakening up, perfectly normal |
6th Oct 2012 8:42pm |
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 |
So, what should I be looking for on the fob to identify whether it has aux heating? |
6th Oct 2012 8:47pm |
You will need a different fob |
6th Oct 2012 8:50pm |
A separate fob with on and off if its a pre 06 it's bigger than the key RANGE ROVER 04 TD6
6th Oct 2012 8:57pm |
Many thanks, should all Vogues have this or was it an optional extra? |
7th Oct 2012 11:40am |
At least on the earlier cars, all diesels had it, but being able to turn it on and off from a distance with the remote, was optional. Irrespective of trim level. 2011 Range Rover Vogue SE 4.4 TDV8
7th Oct 2012 11:58am |
Exactly. All diesels have the aux heater to aid in heating the large interior on very cold days - diesels are just too efficient and don't put out as much waste heat
7th Oct 2012 3:14pm |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
so without the key fob how does the aux heating work as i have a td6 and anything to get it warmer quicker on the morning would be cool! |
8th Oct 2012 12:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35392 |
there is a timer function in the menu andy... ... - .- -.
8th Oct 2012 1:00pm |
so that means that you can programme for it to come on automatically? if you do that will it come on every day on its own even when you arent in it? or does it need the key to be in the ignition for it to work & am guessing below certain temperature? |
10th Oct 2012 8:07am |
I'm slightly unsure myself on this bit. I thought it came on to heat the interior up provided its set on the aux heating thing. Not sure if it only comes on once and you have to reprogram it to come on again the next day.
10th Oct 2012 8:50am |
