Home > General > Why bother with F'ing mechanics!?
dan_uk_1984
As per subject.
I got my local mobile mechanic out to replace the bottom PCV hose as it's a complete pig to do and quite frankly I have better things to do with my time. I've used him before to do messy things like oil changes and he's been very good previously.
However this time he broke a pipe one of the PCV hoses connects onto on the main PCV valve casing which means replacing the whole unit (£60) plus fitting. For now we've araldite'ed it back together but I'm not convicned this will last more than 2 miles down the road.
Not only that but whilst on top of the engine to reach things he knelt on the e-box and put his knee through it!
F*ckety F*ck F*ck is all I have to say. I wish I'd done it myself now so that at least if I'd broken it I would have known it was down to my own incompetence rather than someone elses. I dont expect him to pay for the replacement PCV part but the eBox lid I would have expected him to replace!
Rant over.
Post #14405 6th Mar 2010 12:25pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
i would expect him to pay for what he broke or least meet half way i feel your pain Censored 02 Range Rover HSE Zambezie silver 4.4
Post #14413 6th Mar 2010 6:01pm
scotty7
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
quite agree,,
best to do as much as you can yourself,
it may take you a few hours more, but a least you know that its done right.
hope you get it sorted ok
cheers scotty
Post #14429 6th Mar 2010 7:56pm
dan_uk_1984
Replaced Hose:
Post #14433 6th Mar 2010 8:23pm
dantheman
Shameful - and not just the condition of the hose!
Feel for you man.
Post #14442 7th Mar 2010 2:12am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
That's awful,
He should pay for the damage he's done!
On a side note how do you know you need a new hose? What do I need to check or does the car display signs. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #14443 7th Mar 2010 8:52am
Andy
Before I became 'plod', I was an engineer for 20 years. I've repaired most things, from cars when I left school, to Fork Lift Trucks and have seen most other things in between. I'm glad I can do my own repairs and I will only rely on a dealer/specialist for anything that involves being plugged into a computer to diagnose.
In the last week, I've changed all 4 discs and pads and the 2 bottom arms. I get the bits at discount so I save a small fortune. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14465 7th Mar 2010 7:03pm
nbunney
Noddy Buy a Hawkeye and then you will have no need to grace the dealers Thumbs Up
Post #14477 7th Mar 2010 8:09pm
Andy
Whats that then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14490 8th Mar 2010 8:06am
nbunney
A very good code reader.
http://shop.difflock.com/download/Hawkeye.pdf
Post #14493 8th Mar 2010 8:15am
dan_uk_1984
They are dear though. My USB code reader cost £30 from the internets and plugs into my laptop. Will do everything in the engine. Coupled with the iBus interface (£40) I can code the nav, TV, LCM, PDC till my hearts content.
Post #14494 8th Mar 2010 8:53am
Sadly I had a similar experience when my TD6 was serviced by a local independent garage. Although they used genuine parts from the local Dealer and were fine at what they do (and of course cheaper than a service at the dealer) , only when I decided to do an interim service prior to my European road trip did I discover why my mpg had dropped.
They had not refitted the air cleaner housing properly and as a result the air box was sucking in leaves, debris and much, the filter was black and it can't have done the performance any good.
You can see the piccy here:
New Filter with the service kit:
Old Filter - slightly different colour!
 Discovery 4 HSE
Post #14497 8th Mar 2010 10:23am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Dan - sorry to hear of your problems.
Any chance of a sticky on what recommended bits you need to put together for a USB code reader (I don't know why or if you need an iBus interface for example) ? If it's only £30 then I would be happy to change some of my settings by plugging in a laptop !
Post #14498 8th Mar 2010 11:23am
M44K TS
Bloody hell RR, that's one of the dirtiest air filters I've ever seen! You sure they didn't accidentally use it as an oil filter instead? Laughing
Dan, I'd be interested to fins out a bit more about the iBus interface, there's a few things I'd like to change, like the auto locking etc. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #14499 8th Mar 2010 11:58am
dan_uk_1984
Info on the USB OBD Code reader: http://www.fullfatrr.com/forum/topic775.html
Info on the iBus interface: http://www.fullfatrr.com/forum/topic1094.html
Post #14502 8th Mar 2010 12:21pm
