![]() | Home > Technical (L322) > coolant pressure |
Is it not marked on the coolant bottle cap? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35658 ![]() ![]() |
on rave? ... - .- -.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
As above it should be on the cap. No longer FF owner but still interested. Present car Jaguar XE
mattyboy Member Since: 14 Feb 2012 Location: Colchester Essex Posts: 28 ![]() ![]() ![]() |
mine just has 200 on it??? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
2 atmospheres.
200 kPa which equates to 29psi or 2Bar.
Higher pressure allows for higher temperatures before the water boils and turns to steam |
Thanks for that, the reason I asked was last week my header tank burst open (which I know is a common fault) So I thought i'd just check the system pressure to make sure that it wasn't caused by HG failure. Which I'm pleased to see it wasn't!
