Home > Technical (L322) > Touch screen
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
Touch screen
This week my touch screen when switched on starts to pulse on and off at 2 sec intervals also the radio cd and tv buttons on screen flash to Gray when the music goes off also when I take the key out I can hear a pulse feed back for a short while !! Any ideas guys
Post #144443 3rd Oct 2012 9:03am
simonmanx
I've now got a loud clicking through the speakers when turned off whilst driving Sad
Post #144473 3rd Oct 2012 2:32pm
simonmanx
No water in the floorwell either ive checked this How do I do a (hard reset ie battery disconnect ) ?
Post #144512 3rd Oct 2012 7:52pm
ok, try the battery procedure if that doesnt work then it 'could' be signs of low battery voltage . ... - .- -.
Post #144575 4th Oct 2012 7:24am
simonmanx
new battery fitted 110ah 950 cranking but still have problems my floorwell is dusty and no signs of water the sat nav works fine but no sound the tv will serch but no soun apart from pulsing white noise the radio is the same just pulsing white noise cd wont play the radio cd and tv are slow to respond to touch screen prompts ANY IDEAS GUYS basically i still have the radio cd and tv icons blinking black to grey and the sound pulsing white noise when icons are on highlighted black Big Cry
Post #145652 9th Oct 2012 7:23pm
BrianC
I had this and it was a faulty Bluetooth module. Also check all the most fibre optic plugs.
Ps dont forget to wait till the light stops flashing on the on off button at the touch screen then the system is off
Post #145663 9th Oct 2012 7:41pm
simonmanx
it never stops flashing really and i didnt wait is that a problem ??? how can i isolate the blue tooth module r has anyone got a spare ??
Post #145669 9th Oct 2012 7:57pm
simonmanx
Big Cry
Post #145794 10th Oct 2012 11:30am
simonmanx
Anyone got a spare amp ????
Post #145843 10th Oct 2012 4:55pm
BrianC
To stop the light flashing once your doors are open wait a few minutes and it will time out.
If you open or close any door or press the key it will come on again.
I unplugged the Bluetooth module when it was flashing and destroyed the Bluetooth unit
Post #145855 10th Oct 2012 5:17pm
