Home > Technical (L322) > What's the difference?
Andy
Just seen this on Amazon:
It's for VW Audi and Skoda
It looks the same as the RSW Allcomms cable I bought recently.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #144298 2nd Oct 2012 6:21pm
SteveMFr
Site Sponsor
Hi Noddy,
The board will be different although as far as basic comms go it will actually be quit similar. But Storey has added a security feature so that it will only work with his sw with a key. The housing is prob the same. I have the same one as well (not RSW - generic VAG)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #144302 2nd Oct 2012 6:30pm
fisha
standard obd2 uses standard pins so will work in any car ... but that only gives you obd2 stuff.
if you want any of the manufacturer specific communications ( EAS, body control, heating etc) , then they often use different pins to talk ... which the generic cables likely wouldn't have fitted, plus can talk at unique communications rates ... so in short, needs different hardware chips inside a connector which looks the same. V8 or else ...
Post #144303 2nd Oct 2012 6:32pm
Andy
I've just ordered it for my Golf. Reason I asked was just in case I could have used the RSW on the Golf 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #144316 2nd Oct 2012 7:24pm
