Home > Technical (L322) > Webasto FBH fault code glow plug sensor short to ground |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 |
Hi
28th Sep 2012 11:01am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35371 |
just wondering if its cold enough to start up.. ... - .- -.
28th Sep 2012 11:04am |
Should be cold enough as its below 14'c it will fire up or something like that in the temp range. Also should fire up anyway when the engine is cold and outside airtemp is low like now to help heat the block and cabin.. guesing this will lead to a cold cabin for a few miles until enough heat is in the block... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Sep 2012 12:29pm |
More info in case i means anthing to someone...
29th Sep 2012 2:07pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Hi
30th Sep 2012 8:02am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
Try Strathearn Engineering, near Auchterarder. They have an Autologic system, and can force the FBH to run |
30th Sep 2012 8:05am |
Hi again
- nope - pretty sure i cannot hear anything apart from fans running. What does that mean?
Thanks Mikey. Might give that a go - although it's a bit out of my way and difficult with work. Found a place on ebay (CAV automotive who do a full refurb post and return for £315. Not sure if that includes the ECU though - I'll have to ask them. |
30th Sep 2012 5:18pm |
Ok so it's not getting that far in the sequence
30th Sep 2012 9:07pm |
Thanks for that advice.
1st Oct 2012 12:21pm |
JR's info is spot on.
2nd Oct 2012 7:35am |
Hi Steve
2nd Oct 2012 7:32pm |
Thanks steve
2nd Oct 2012 9:41pm |
Cool
2nd Oct 2012 10:48pm |
The FBH fuel pump is best heard under the car as this is where it's mounted
3rd Oct 2012 7:52am |
Hi Guys,
3rd Oct 2012 10:42am |
