![]() | Home > Maintenance & Mods (L322) > serpentine belt whine |
Could be the tensioner roller, I usually replace that with the belt. That is the "cheapest" problem, could also be any of the other items driven by the belt, A/C compressor, Power steering pump, Water pump, Generator.......
Thelord67 Member Since: 19 May 2012 Location: Stockport Posts: 27 ![]() ![]() ![]() |
Goldsax, the intermittent noise you describe I may have the same noise, can you provide more detail, plus does it only do it on start up? Range rover tdv8 56. Vogue
Use a trigger spray bottle to spray water on the belt, if the noise disappears then the belt is possibly glazed up on the outer edge, if the noise is still there then spray some water on the tensioners to try and pinpoint the noisy one.
