Home > Maintenance & Mods (L322) > ZF 6HP24 into Td6 ? |
I would be interested to know the answer.... |
28th Sep 2012 6:57am |
You can do anything with enough time and money, but even if the bus system for the ECUs is the same, the transmission ECU will need to be programmed to match the parameters presented by the RR and will need to present and understand all the correct status messages that it encounters in comms with the other vehicle systems. I would be extremely surprised if ZF gives you an answer simply because it has never been done - they will not be likely to start venturing guesses.
28th Sep 2012 8:36am |
+1 SteveMFr. MY 2010 5.0 SC Galway green and sand interior!!
28th Sep 2012 8:51am |
As above it would take a lot of time and if you were good coding and diagnosing these types of systems then maybe a few hours here and there if you had another car to use would be ok but not really.
28th Sep 2012 10:43am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1387 |
HAving a quick look round the web and the sonnax things ...
28th Sep 2012 6:33pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Have to express my ignorance kingpleb, what do you mean by lock up ? .
29th Sep 2012 12:36am |
The conditions causing the torque converter to lock and the clutches as well. I'm sure rrphil could explain it better but compared to the latest boxes the gm slips all the way upto 30ish and at light throttle as well. Try a new disco 4 on a test drive and see what I mean FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
29th Sep 2012 5:20am |
From Wikipedia:
29th Sep 2012 10:20am |
I am no longer so ignorant and pleased to say that so far have not experienced this effect ? .
29th Sep 2012 11:32am |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
We have the 5L40E in locallly built Commodores, but like the BMW X5's all the valve bodies are different. The one thing that is consistant across all variants here is that the torque converter is usally the first point of failure. One local specialist stated that GM had a batch of badly bonded T/C clutch linings; if you look at most failures you will find failure of the T/C clutch linings was the start,and the valve wear just exacerbated the problem. As was stated here on the forum if you go thru LR part numbers there have been 3 different numbers for the T/C's.between 2002-2006.
1st Oct 2012 3:22am |
