![]() | Home > Technical (L322) > Ongoing Droning Noise, Suspect Gearbox Fault :( |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Any updates? 5.0 supercharged autobiography
roadnutter Member Since: 19 Sep 2013 Location: Bridge Of Weir Posts: 23 ![]() ![]() ![]() |
I know this is an old post but I thougth I'd add some ideas based on my experience. Hopefully this can help others.
ij.brooks Member Since: 12 Oct 2013 Location: Newcastle upon Tyne Posts: 30 ![]() ![]() ![]() |
I was having a similar noice coming from sounded like rear wheels, so thought my bearings had gone, left it for a few weeks and then noticed some oil on Christmas Eve coming from the middle of the car, had a look under and oil was spread around transfer box, so took to the local indy when they opened after Christmas, eventually they found that the input shaft bearing had collapsed and that had caused the leak and noise. Car eventually fix and collected on Thurday and bearing noice gone and car running smooth after a new transfer box fitted, so your issue could be in a similar area of rear diff and transfer box. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
I am no expert on the ZF gearbox, but I seem to remember that they can suffer from shuddering at around the 75k mark, and that power flushing the gearbox is the way to cure this. Cam Tech Craig or RRPhil (gearbox guru) should be able to tell you more. When my GM 5L40E box when tits up, there was shuddering at 30 - 52 and then it would all settle down and behave it's self again, classic sign that the torque converter is about to pop it's clogs. I could make it stop by either, making it kick down or by knocking it into sport mode, like manual but but only move the gear lever to the left not up and down. If your gearbox is slipping above 55 then I suspect that all the clutches are worn out, and it needs a rebuild. Yesterday I couldn't spell Engineer... Today I are one!
Alex Millar Member Since: 05 Jun 2015 Location: Glasgow and Arran Posts: 24 ![]() ![]() ![]() |
Hi there. Just bought my Range Rover yesterday after 35 years ago as 18 year old boy being in awe of it's ride and presence when I got to ride in one. I drovetit from Sussex north to Glasgow (400 miles) and although it has done 180000 miles had been well looked after (2004 4.4 V |
