Home > Maintenance & Mods (L322) > battery booter packs.advice |
Why not use an overnight charger/conditioner ?
26th Sep 2012 12:34pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
the car is used on the school run.....30 mins each way
26th Sep 2012 12:40pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
I assume the 13+ is volts not amps and if so doesen't sound very reassuring.
26th Sep 2012 12:56pm |
I always go for the biggest capacity battery that fits into the space, just to be on the safe side.
26th Sep 2012 2:26pm |
Largest battery available is a Bosch one - do a search on here. About 1000 cranking amps I recall.
26th Sep 2012 2:35pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7953 |
As per the other thread here get the Bosch from Europarts - best £100 you will spend.
26th Sep 2012 6:52pm |
i dont understand Member Since: 03 Sep 2012 Location: Herts Posts: 4 |
Alternator output should be 12.5v MINIMUM 14.2v is desirable. But that can vary if smartcharge is used!(not applicable here!)
26th Sep 2012 7:46pm |
