![]() | Home > Technical (L322) > 4.4v8 Oxygen sensors / Engine management light. |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
My initial thoughts would be that, now the cat has been welded, clear the faults on the ECU and check again in a week or so to see if any faults have returned.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
How easy are the O2 sensors to replace? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Rears are easy , fronts are hard (difficult to get the spanner in) especially if the thread is b |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
Personally, I would get the errors reset first.then if you can get the adaptive values of the ecu reset too. ( may take a more advanced diagnostic tool for that )
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
Im thinking of buying the sensors, as it was a Land Rover dealer that done the diagnostics and cleared everyithing so sensors under the fault code P0134 and P0154 are still not reading anything. Does anyone have part numbers for these sensors? Both are number 1 sensors on either bank.
Both are #1 sensors on each bank ...
I havnt actually checked. But the fault appeared before the welding was done.
An update on this. So just after my last post I discovered my PCV hoses had failed, so replaced those along with the valve etc. lso replaced the two front O2 sensors, spark plugs , oil and filter, and finally the MAF. Unfortunately the EML has still not disappeared. I reset the engine ecu using an IIDtool. It returns everytime. Although the engine is running much smoother now after the work which has been done it is only getting about 11-12mpg. Also the nearside bank (bank2 i believe) is running rich and is producing soot under throttle. I did however buy and fit universal O2 sensors, which im now regretting. As being non OEM throws doubt into them working.
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
1 bank will run rich if the O2 sensor on that bank is giving incorrect information to the engine computer.
Thanks Jim2RRs. I'll try and get out to do that later today, although the weather has taken a turn for the worse. Is it always the sensors pre-cats that can affect over fueling, or do the sensors after the cats also contribute to this?
You can actually swap the connectors so you don't have to remove/re-install the sensors themselves |
Did you replace the MAF with a genuine one ? V8 or else ... |
Yes replaced the MAF with a genuine one. |
Yeah - I replaced with genuine after trying an aftermarket one ... costly mistake .. but lesson learned I suppose.
