When you say it causes the bluetooth to stop working... does it do this... see below.
The reason i ask, I had the iPOD connection fitted before I ever got around to connecting the phone (bluetooth) to my 07 Vogue SE after I bought it. I've had problems with the phone coming up as not fitted, but it will accept incoming calls and if I dial from the phone handset it will then come through on the handsfree, in this state once I end the call it tells me on the phone screen that I've entered an incorrect PIn??? my phone doesn't have a PIN set up!
what I have found is when I unlock the car with the remote on the key, the stereo power button LED flashes for what seems like ages, but I guess is somewhere between 30 seconds and a minute. If I wait for this to stop flashing before putting the key in and starting the engine, it will in most instances (29 in 30) connect properly. I've taken it back to the dealer, but they say that this is normal for the connection and you should wait for the led to stop flashing.
To me this seems crazy, so I wonder is it the same for you? Is it normal for the new models to have this LED flashing after opening?[/quote]
