Home > Technical (L322) > Transmission message? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
new battery needed?...low voltage , as in first thing in the morning could cause this error... ... - .- -.
16th Sep 2012 12:37pm |
keefy1959 Member Since: 14 May 2012 Location: essex Posts: 31 |
thanks for your help again Stan, I'll check this out and let you know how i get on!!!
17th Sep 2012 4:21pm |
17th Sep 2012 4:32pm |
I have a similar issue : bong, transmission fault, limited gear change available. Nothing seems to happen to the driving. Last night I opened up the box with the transmission ECUs. Disconnected the battery leads and liberally sprayed the plugs, fuses etc. with contact cleaner. Removed/disconnected all of them and put them back (did that a few times).
17th Sep 2012 6:36pm |
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 |
[Dredging this one up] Did a battery change work? I've had the same message the last couple of mornings, for about 5 seconds as soon as I turn the engine on, then have it vanish. With the Audi and the Porsche, seeing the traction control/ABS lights come on first thing on a winter's morning has always meant that the battery is on its way out. Just wondering whether it's the same on the RR, or whether it is something else. Range Rover 4.2 SC AM V12VS Porsche 991.1 Turbo S Mini JCW conv |
5th Dec 2013 4:09pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I get Special programs off even though I have replaced battery it still happens about every 3 in 10 starts. Have a transmission fault only once due to low battery voltage.
5th Dec 2013 4:16pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
This only occurs when I have parked at McDonalds (which is thankfully very very rare). No-where else. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
5th Dec 2013 4:28pm |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 214 |
Just had the rear diff actuator motor replaced on mine. Got the bong with the "Transmission fault traction reduced" fault on the way home from work the other day. It reappeared on each startup afterwards so I booked it into my local dealer. They read the faults and checked various other links in the system and found the diff lock actuator motor was faulty so it was replaced at a cost of 690EUR (about 580GBP) plus 2.5 hours labour (including fault finding, replacement and test drive). Parts replaced were LR032711 and LR041282.
15th Apr 2017 12:35am |
