Home > Technical (L322) > Left bank too rich
ebajema
Left bank too rich
Hi Guys and Girls,
I keep getting a check engine light coming on every few days. I clear it and then a few days later it comes back. Today I captured some of the data to see if that gave me a hint. A few things I noticed :
- MAF absolute pressure was around 37 kPa while atmospheric was 101 (no units but assume it is also kPa)
- Long term fuel trim bank 1 (left ?) is around -2.94
- Long term fuel trim bank 2 (right ?) is around -1.28
- Short term fuel trims both 0
- O2 sensors are 0.69 Volts and 0.74 Volts, difference stays the same
Can anyone give me hints / tips on what could be causing this ?? I have an Excel sheets with all the values and an AVI clip showing the numbers while running.
I would really appreciate your help.
Cheers,
Eugene MY 2010 5.0 SC Galway green and sand interior!!
Post #61335 23rd Apr 2011 5:13pm
dan_uk_1984
I cant help you with specific suggestions, however; lean or rich codes can be symptoms of the following (in order of likelyhood):
Vacuum Leak (allows unmetered air)
Dirty MAF (incorrect fuel/air mix)
Failing MAF (as above)
Failing spark plug (unclean burn)
Post #61336 23rd Apr 2011 5:41pm
bogie
I had same errors and it turned out to be perished inlet manifold pipe, 2 were pretty bad, so replaced for £25 ish and reset, never been since cheers
bogie
Post #61347 23rd Apr 2011 9:39pm
ebajema
Thanks for the suggestions guys, I will start on them in the next few days.
After posting I got hold of some surgical spirit and cleaned the MAF. Lot of dirt came out and when I put it in it seemed like the ECU had to re-learn how to run it. Hope to know more when I take it for a test drive tomorrow. After the test drive I will do another data capture and see if the numbers have changed.
The spark plugs are new and the old ones didn't look too bad when they came out bit "sooty" so a bit rich already. Thing with this car is, it sat still in the hot African climate with two rainy seasons for two years so it could be just fouling of the MAF sensor. The original air filter was still in and it was full of crap, now it has a K&N filter.
Will definitely check the vacuum pipes, although when I disconnected a vacuum hose while doing the spark plugs, it let in quite a bit of air, indicating that at least that part of the system still maintains vacuum quite well.
Anyway, will keep you posted here !! MY 2010 5.0 SC Galway green and sand interior!!
Post #61353 23rd Apr 2011 10:49pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
Hi Ebajema. How did you get on with this issue.....Dirty MAF?
Fraser
Post #141022 13th Sep 2012 10:52pm
ebajema
Hi Fraser,
Nope, it wasn't the MAF. It is most likely the crappy petrol from our "main" fuel station plus two years of sitting still in Lagos (causing the petrol to gum).
After cleaning the MAF and changing the oxygen sensors on that side, it still didn't go away. So I started running injector cleaner in the fuel. Helped a bit but still not perfect. Then we had to use another fuel station for a bit and the problem went away. So now I hardly ever have a problem (CEL is on now but that is probably because my driver filled it up at the "old" fuel station, I need to check and tell him not to go there).
Seems the S/C is a bit sensitive to bad petrol.
Cheers,
Post #141236 15th Sep 2012 11:15am
SteveMFr
Site Sponsor
Rive gauche trop riche? Paris?
sorry
Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #141706 18th Sep 2012 10:28am
ebajema
@Steve Laughing
Current batch of lousy petrol is throwing up a new one : Left bank too rich, right bank too lean Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #141713 18th Sep 2012 10:49am
